Mini-Z Discussions => Mini-Z Formula 1 => Topic started by: Nic-z on February 16, 2008, 08:18:16 PM
Title: F1 101
Post by: Nic-z on February 16, 2008, 08:18:16 PM
Okay I got my f1 in today, it has alot more hopups than I thought (since it was stock I guess anything was more than i thought) I test drove it on my track, and it pulls really bad to the right, I maxed out the controll setting, so i need to make the adjustmen on the board, only problem i can't get the dang body off! so whats the catch.
Title: Re: F1 101
Post by: Nic-z on February 16, 2008, 08:35:21 PM
nm I just broke it....jk.
Title: Re: F1 101
Post by: briankstan on February 16, 2008, 08:57:14 PM
right above the rear suspension plate you can use a little screwdriver to get it off,  it's a little tricky the first time.   Make sure you only adjust a very little at a time.  Don't forget to center your controller befor you do it.
Also the helios has a sub:trim.  you use it first and then fine tune with the standard trim.
Title: Re: F1 101
Post by: Nic-z on February 18, 2008, 12:31:47 PM
okay on the board the pot adjuster must be broke cuase it doesn't do anything, I used the sub trim to Right 50 and works fine, I will see when my two other F1's come in to decide how well it compares, but I will say for 100 bucks I got the carbon rear supsension, kysosho ball diff, alm knuckles alm toe bar, alm rims, bumper guard, and new tires. I'll say its a lot more than I expected for that.  And for the other fifty I got a nifty practice 01 car.
Title: Re: F1 101
Post by: Russ on February 18, 2008, 06:35:12 PM
$100 is a great deal. I have a complaint though. IT LOOKS JUST LIKE MINE!! LOL!!!
I hope you get some different bodies with the other ones that you can race with so we can tell the difference. I guess for now I'll just have to look for the car out in front to see which one is mine.  ;)
Title: Re: F1 101
Post by: Nic-z on February 18, 2008, 07:31:22 PM
I like that idea, that way you'll think you're driving your car when infact its mine....i set up my track saturday, so i am doubling up on practice time, your days are numbered Russ lol.  And yes I have two other bodies, but no promises if I choose another one, I really like this one lol.
Title: Re: F1 101
Post by: briankstan on February 18, 2008, 09:38:48 PM
well you both will be fighting with Chad for the top honors with the McLaren,   Unless I'm on my game,  then it's ferrari all the way.  ;D
I finally ordered my PN mount for my F1 along with a top shock...
Title: Re: F1 101
Post by: Nic-z on February 18, 2008, 09:56:06 PM
what part number I can't ever find it.
Title: Re: F1 101
Post by: briankstan on February 18, 2008, 09:58:57 PM
for what?
Title: Re: F1 101
Post by: Nic-z on February 18, 2008, 11:51:06 PM
rear dampener...
Title: Re: F1 101
Post by: briankstan on February 19, 2008, 10:43:06 AM
I got the rear spring.    I still need the damper,  it was out of stock everywhere I looked.
Title: Re: F1 101
Post by: Nic-z on February 19, 2008, 10:57:41 AM
oh okay, I figured as much but I thought I'd ask.
Title: Re: F1 101
Post by: Russ on March 07, 2008, 09:31:09 AM
They have them on ebay. Or I'll sell you mine.
I took my rear damper off. I just could not get it to work right with my motor mount. I think I just want the rear srping thing like yours. For now I'm just running the Atomic shock that came with my damper plate. I dont like it that well but I need it to because just the carbon rear plates alone wont hold the car up. Eventually I will upgrade my motor mount to the PN one. That is if I decide to keep the F1. I'm really frustrated with it right now.
Title: Re: F1 101
Post by: briankstan on March 07, 2008, 09:45:47 AM
don't give up on it.   once you get it handling the way you want you will like it.  8)
Title: Re: F1 101
Post by: Russ on March 07, 2008, 10:25:48 AM
Believe it or not... I got one of my boxes of RCP put together last night. WooHoo!! I set up a wide oval in my front room. LOL!! Anyway I ran my F1 on it because I had fixed some things and wanted to test. Anyway it seemed to be ok turning to the right or clockwise but would spin out easily to the left. I was going to try some shims between the side plates and the chassis to correct it. I presume its caused by tweek?.
I tried to fix the stutter in the steering. I took it all apart and cleaned the pot with motor spray and cleaned all the servo gears out. It works way better but there is still a slight stutter about 10% of what it was.
Title: Re: F1 101
Post by: briankstan on March 07, 2008, 10:31:14 AM
well Most Mini-z's have some shutter.     the spin outs sound like tweak, try the shims and see if that fixes it.
Title: Re: F1 101
Post by: Nic-z on March 07, 2008, 11:20:16 AM
my king pins were the main culprit of my steering problem, its like 90% better I will try to get the rest of it out by tweaking the body next week, this weekend I am headed to vegas to try my formula boats in the pool!
Title: Re: F1 101
Post by: Russ on March 07, 2008, 11:21:56 AM
I bet you could find a closer place to run your boats!! LOL!!!  :D  Have Fun!!
Title: Re: F1 101
Post by: Nic-z on March 07, 2008, 11:23:18 AM
biz trip, so ya know
