Mini-Z Discussions => Store => Topic started by: Nic-z on June 06, 2008, 07:35:15 AM
Title: 64 pitch question.
Post by: Nic-z on June 06, 2008, 07:35:15 AM
I need to get some 64 pitch gears, do I need that bearing thingy? with the spur gear?
Title: Re: 64 pitch question.
Post by: briankstan on June 06, 2008, 08:21:07 AM
you will need it,  it goes in the supr gear.    after you have 1 for each diff you need you can get just the gear.
I have a package of 2 of the thrush bearings, so you could go that way if you are doing more than 1 diff.
Post by: Nic-z on June 06, 2008, 09:57:35 AM
can I just swap out the bearing as I swap out the spur? or are they diff. sizes? I was planning on buying the 18.88 64 kit that comes with three spurs and some pinions.
Post by: briankstan on June 06, 2008, 10:07:35 AM
it also comes with the bearing.   you can use it in any of the spur gears you want.  you only need 1 per diff.  if you are just changing the gear you can use the same bearing.
Post by: Nic-z on June 06, 2008, 11:19:53 AM
sweet thats what I will get then, once the body is in stock.
