May 28, 2024, 01:55:12 AM *
Author Topic: Porsche Cup - (Close to Box Stock Class)  (Read 29421 times)
« Reply #3915: December 12, 2018, 11:40:17 AM »
Rules (updated 1/22/20) And will be updated as we figure this out
Chassis:
  • MR-03-N RM
  • 90mm wheelbase
  • Ready Set: - Kyosho MINI-Z MR03 Porsche 911 GT3 RS/RM.
  • RWD Part Numbers 32321W-B, 32321OR-B, 32321S-B (these are the white, lava orange and silver).
  • Sports 2 Part Numbers 32231OR-B, 32231S-B (these are the lava orange and silver, not sure about white).
Radio:
  • Ready Set included transmitter only, no upgraded radio's
  • Perfex KT-531P FHSS 2.4GHz
  • Perfex KT-19 FHS 2.4GHz
Body:
  • Porsche 911 GT3 Autoscale Only
  • Mirrors may be removed (on purpose or accidentally Shocked ).
  • Stickers and decals for the body allowed and encouraged.
  • Headlight Kit - MZW429R Not Required but highly recommended <--- Freakin Cool!!
  • Taping body on for racing is allowed.
Suspension:
   Front
  • No front suspension modifications. May clean and polish parts.
  • Stock front springs, arms, holders
  • Stock plastic knuckles, or aluminum Kyosho (R246-1310) 0 camber allowed.
  • Stock king pins, in stock configuration, no reversed king pins etc.
   Rear
  • Stock T-Plate, or PN Carbon T-Plate #4 Medium Soft (MR3006).
  • Stock plastic motor pod
  • Stock rear shock and spring
  • No damper plates.
  • No side springs
Tires:
  • Front Tire PN X-15 (RXF15).
  • Rear Tire PN KS Medium (KS2828).
  • Taping allowed
  • Truing Allowed
  • No Sauce or Additives
  • Tires may be cleaned with a 70% alcohol solution
Wheels:
  • Stock or aftermarket plastic only.
  • No aluminum wheels.
  • Aluminum wheel nuts ok.
  • Front wheels - Narrow +1-1.5 offset (stock is +1.5). Max 8.5mm width.
  • Rear wheels - Wide +0 offset. Max 11mm width.
  • Bearings - Stock or PN600129 - No ceramic - Cleaning and re-lubricating ok.
Batteries:
  • Four (4) AAA size batteries.
  • Alkaline, Ni-MH or Ni-Cd batteries.
  • No other type of battery may be used.
Motor and Gearing:
  • Kyosho MZ9P Motor from RTR.
  • Motors are to be run as is, any tampering with the motor will result in disqualification. If any race official suspects motor tampering, the driver will be subject to disqualification.
  • Fixed gearing: Stock 43 tooth gear diff.
  • 6 tooth pinion for small track (≥ 2 wide L).
  • 7 Tooth Pinion for  large track (≤ 2 wide L) Ice Melter Race.
ESC:
  • Stock Board FHSS or FHS 2.4GHz.
  • No Gyro's.
Other rules: TBD - The spirit is to keep the car box stock.
« Last Edit: January 22, 2020, 12:32:07 PM by Russ » Logged
