Monster Trucks => Venom Mini Giant, Trinity Clash, A Tech, Leo X Monster trucks. => Topic started by: Nic-z on February 11, 2008, 10:11:54 PM
Title: got my venom today
Post by: Nic-z on February 11, 2008, 10:11:54 PM
So it arrived I will be posting pictures soon, quick question, the battery has this dean plug and I don't have a charger for it?  lol the motor says fireball and thats about all I can make of it so far.
Title: Re: got my venom today
Post by: Nic-z on February 11, 2008, 10:15:17 PM
okay so is there a tut on the steering mod you guys have done to it? I need to get it ready by next race, also what should i do about the battery, I might be getting a charger for it in the next shipment who knows. coments suggestions?
Title: this site has great help
Post by: CLODGUY on February 12, 2008, 12:08:52 AM
http://www.one18th.com/forums/showthread.php?t=50621
    Hope this helps
Post by: Nic-z on February 12, 2008, 12:55:31 PM
YEah, what did you guys use to remount your servo? zip ties or did you fab some brackets out of alm?
Post by: briankstan on February 12, 2008, 01:01:10 PM
it's fabricated out of aluminum angle.   the servo is mounted to it using shoe goo.  it works really well.  I'll find a pic and post it for you.
you can kinda see it in this picture
(http://www.saltlakemini-z.com/sitebuilder/images/Brians_Mini_Giant_6-600x450.jpg)
Post by: Nic-z on February 12, 2008, 01:26:34 PM
nice where can I get the alm? and did you use the oem tie rods?
Post by: Nic-z on February 12, 2008, 01:27:52 PM
oh and link those red servo savers you guys have pls ;)
Post by: briankstan on February 12, 2008, 01:33:50 PM
Luke would have to fill you on what was use.  Russ would also have a better understanding as he just did his.
I just purchased the servo savers from West Valley Hobbies.
Post by: Russ on February 12, 2008, 04:27:41 PM
I have some of the aluminum angle I used if you would like some, you can come over and get it. I beleive I got it at Home Depot and its 1/2 x 1/2 inch. As for what I did just have a look at my Mini Monster gallery. The servo saver is a Kimbrough 131. Its the only red one so should be easy to find. I used a Hitec HS-81MG that I bought at WVH. Also pick up some 3mm 4/40 threaded rod, some ball ends, and 3mm nuts. I used some old Traxxas ball ends I had laying around. Its pretty easy to do if you have a vise, hack saw, dremel, drill and bits, and other various tools. If you need some help I would be happy to.
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXS362&P=7 (http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXS362&P=7)
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXN679&P=ML (http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXN679&P=ML)
Post by: Nic-z on February 12, 2008, 05:14:44 PM
okay I have some servos I will post some pics later let me know what they are, if they'll work and yeah I would dig some of that alm stuff if you got it.
Post by: Nic-z on February 12, 2008, 11:49:32 PM
Okay so I have some pictures posted in my gallery. finally. Not everything is there but soon I'll have everything up. I will have to look at yours Russ and see what exactly is involved I don't know much about the venom to just go off what I know so far.
Post by: Nic-z on February 13, 2008, 08:00:34 AM
Russ, saw the pics on your mini giant, I understand now what you mean, I forgot to post the servos I had, but will this work for the tie rods? maybe you can just buy everything I need and I'll buy your kennon order and we'll see what the diff is.
   TGR 401500 Steering Set with Servo Saver - AtomicMods.com
 (http://www.atomicmods.com/Products/TGR-401500-Steering-Set-with-Servo-Saver__14112.aspx)
Post by: Russ on February 13, 2008, 08:10:37 AM
I dont know if that thing will work for sure. I think its for the TGR Sinister pan car. You might be able to adapt it but without specs of how long it is and what not I would probably suggest doing it the easy way. All of the items you need are available at West Valley Hobbies in Taylorsville off 54th and Redwood. If you have a small servo that will work thats fine but if not the HS-81MG works great. If you need some help making it I can help. As for the Kenon order I'm trying to wait til I hopefully get my F1 so I can see what I need for that.
Post by: Nic-z on February 13, 2008, 08:47:47 AM
Kimbrough 131, Hitec HS-81MG, Also pick up some 3mm 4/40 threaded rod, some ball ends, and 3mm nuts. I used some old Traxxas ball ends I had laying around..............is that all I need from there? any approx cost?
Post by: Russ on February 13, 2008, 09:00:51 AM
Approximate Prices:
HS-81MG     $22
Rod             $3
Ball Ends      $4 (Traxxas 2742X)
Screws        $Free I have some
Nuts            $Free I have some
Angle AL.      $Free I have some
Kimb. 131     $4
Tight Turns   $Priceless
Also I would call and just check to make sure they have everything. 964-1700.
Post by: Nic-z on February 13, 2008, 09:05:45 AM
Russ you da man, thanks buddy, I'll see if I can call and swing by wvh today.
Post by: Russ on February 13, 2008, 09:09:22 AM
If its too far out of your way let me know and I can probably pick up what you need. Or if you get it yourself you could swing by my house and pick up the rest. I'm usually home after 5:00. WVH is open till 8:00pm.
Post by: Nic-z on February 13, 2008, 09:37:10 AM
yeah its not on the way on my commute. but I did find that apexhobby.com in lehi has the same format online shop as wvh so I am thinking they are the same shop, and thats really close on my commute I could give that a try.
Post by: Russ on February 13, 2008, 09:48:34 AM
Those online shops are really quite a generic. They seem to be the same but with different names. I wouldnt trust that. But calling and going in is good.
Post by: Nic-z on February 13, 2008, 10:24:51 AM
Approximate Prices:
HS-81MG     $22
Rod             $3
Kimb. 131     $4
okay WV has everything but the threaded rod. I will call others to check. so far total for parts..30 bucks plus tax, a a 3 dollar rod.
Post by: Nic-z on February 13, 2008, 11:36:23 AM
Okay called around, do you mean for me to get the 3mm or 4/40 rod? WV has 4/40 but no one has the 3mm that I've seen yet.  also wv is the cheapest for parts so far. I might just paypal you the money minus what you owe me if thats okay.
Post by: Nic-z on February 13, 2008, 11:46:49 AM
nm I found hobbytown near my house has everything but no 3mm just 4/40 and the servo is just 17 bucks! ;D
Post by: Russ on February 13, 2008, 01:19:21 PM
Yes its 4/40 threaded rod. I beleive the 3mm nuts go on that. Make sure the servo is the MG (metal gear) version. The non MG would be cheaper but might strip the gears.
Post by: Nic-z on February 13, 2008, 01:27:33 PM
yes its a MG 16 bucks for it too! and only 1 dollar for the rod, this place is sweet lol.
