April 24, 2024, 05:27:49 AM *
Author Topic: Racing Regulations for all Classes  (Read 22204 times)
« Topic Start: January 28, 2008, 09:41:09 PM »
General rules
Lap counting - Will be done with our Corespeedway lap counter
General conduct - We expect all drivers to treat each other with courtesy and respect. Try to race clean and don't crash or block other drivers intentionally. Try to keep emotions in check. This is all for fun, no reason to get upset and be verbally or otherwise abusive. Anybody who is abusive may be suspended or removed from the club.
Attendance - We don't have any minimum participation rules, come once every few months or every race, it's okay. However, since we do have a lot of racing to do in one night please show up on time, or we may have to start without you. If we do start without you, don't take it personal, you can join in the fun at whatever point you show up.
Marshaling - You are expected to marshal your own car. Another driver may be nice and help you out or there may even be non-drivers available to marshal, but don't expect it. If there are others available to marshal please don't yell at them if they aren't moving as fast as you'd like them to.
Mini-Z 2WD
Motor:  HFAY Stock, Kyosho Stock.
PCB:  Stock board (allowed to upgrade to any available Fet. Stacks are allowed) No other modifications allowed. 2.4ghz boards allowed.
Drive train:  Any gears, shafts or diffs allowed.
Bearings:  Allowed, any brand or type. (Rear axle, front wheels only.)
Chassis:  MR-01, MR-015, MR-02, MR-03, MA-010 chassis'. Direct replacement alloy parts allowed.
Tires/wheels:  No Foams, No traction compounds allowed.
Suspension:  Anything goes as long as the stock configuration and stock chassis are maintained.
Body:  Any Kyosho Mini-z, Iwaver, or Xmod bodies. Custom model car bodies allowed as long as they meet the stock dimensions. No Lexan bodies.
Batteries:  Any rechargeable NI-MH 1.25volt, or 1.25volt Alkaline (4 cells only)
Minimum Weight: 175grams with batteries installed.
Wheelbase:90mm - 102mm allowed.
Misc:
2WD Stock  - Kyosho Mini-Z and TRP Scale body only, all windshield and window must be installed.
Body Modifications
- Any Kyosho Mini-Z body including LM bodies and TRP Sacle bodies are allowed, but car must conform to wheelbase and width rules.
- LM-size wheels and tires are NOT ALLOWED. See Wheel Rim and Tire rules for clarification.
- Bodies may be functionally modified with minimal effect external appearance. The following non-comprehensive list of body modifications are allowed:
- Excessive external cutting of the body is NOT ALLOWED for weight reduction purposes. The rear bumper may be removed up to 20mm from the ground.
- Wheel wells may be cut forward or backward to accommodate different wheelbase chassis.
- Wheel wells may be cut or chamfered internally for tire clearance.
- Lower portions of the body may be cut for ground clearance in front, sides or rear.
- Body material may be shaved or thinned internally for weight reduction. Technical inspection officials reserve the right to disqualify any modified body deemed to be too fragile due to excessive material removal.
- Body panels may be reinforced or strengthened internally without affecting external appearance.
- Kyosho windshield and windows must be installed, but can be modified by cutting unexposed internal areas.
- Kyosho headlight covers must be installed, but headlight buckets may be removed or omitted. In the event that a headlight cover is lost, the hole may be covered with a decal.
- Taillights and taillight covers may be removed or omitted.
- Small body parts such as mirrors, canards, exhausts may be omitted or removed to prevent racing damage and debris on track.
The above list is non-comprehensive. The purpose and spirit of the rules is to allow functional performance modifications to the body while preserving the scale appearance and realism. The technical inspector has final authority in the judgment of body modification legality.
Racing rules: Road course racing. 5 minute qualifying may be run if enough people are present, 8 minute mains.  # of Mains depends on participation. Driver that completes the highest total number of laps wins.
2WD Modifed
We will follow the Current Mini-Z World Cup regulations for this class.
Min-Z World Cup Rules and Regs
Formula 1
Drive Train: Any Gears, shafts or diffs allowed.
Chassis: Stock Direct replacement alloy parts allowed.
Suspension: Any spring or Carbon Fiber Plates.
Custom bodies: Kyosho F1 body, or Custom Painted White body.
Batteries: Any rechargeable NI-MH 1.2volt, or 1.25volt Alkaline (4 cells only)
Minimum Weight: 200grams with batteries installed.
Overland
Motor: Stock, HFAY Spec,  Speedy 05
Drive train: Ball diffs, lockplates and delrin main gears allowed.
Chassis: Stock, colored chassis allowed, any alloy parts are allowed.
Tires/wheels: Any.
Suspension: Any.
Bodies: Custom bodies allowed if they meet stock dimensions.
Racing rules: 8 minute timed race. The highest total number of laps wins.
Monster Truck Race
General: Must be a Venom Mini Giant, Trinity Clash, A-Tech, Leo-X or Kyosho Mini monster.
Motor:  Any
Drivetrain: Stock. Differentials may be locked.
Chassis: Stock, only minor modifications allowed
Tires/wheels: Stock size, can be modifed or sanded.
Suspension: Any shocks allowed. No other mods allowed except alloy parts on the Mini monster. Steering modifications allowed on the Mini Giant.
Body:  Any
Batteries: Any 4-7 cell Nimh, Lipo's allowed.  No brushless.
Racing Rules - Trucks run on separate but identical courses or a chase type course. At least two tires must go over every obstacle during the run. If an obstacle is missed the truck must go back and go over the obstacle, otherwise the run does not count. No marshalling. If a truck turns over, gets stuck or is otherwise unable to continue that racer
forfeits that round. If both trucks are unable to finish, we re-run that round. Hitting a cone is not a penalty, however the truck must go around the cone. First truck to cross the finish line of it's course while hitting every obstacle with both wheels and rounding the cones wins that round.
Race format: Races - Each truck will have 3 rounds against every truck that is participating.   1 point will be scored for each round that is won.  The points will be scored for the racing season.  the driver with the heighest total points for that season will be crowned the Monster Truck champion for that Season.
Race format: Freestyle - Each driver will have a 2 minute timed session, During this time the driver will score based on selected judges, 1 point will be deducted from judges combined score for every time you have to turn you truck over if if flips and can't continue.   Obsticles can include several different styles of Jumps, Crunshable paper cars, buses, etc.   The Driver that aquires the highest total of points during the 2 minute session wins the event.
« Last Edit: December 23, 2009, 04:39:56 PM by briankstan » Logged
« Reply #1: December 23, 2009, 04:47:00 PM »
Rules updated to clarify some informaion.   **12-23-09**
